02BigD
Rear main has been leaking for a bit, and it got worse since i came back from vacation. Is there a special tool to remove the old seal and wear sleeve? Where can one get the tool to install the new one from?
Just use the flex plate spacer. The seal will come with the wear sleeve installed. Apply your rtv and loctite and put three bolts into the crank and turn each one a little at a time till the ring is seated. When you get the seal close to the rear cover you will want to start the bolts that attach the seal so that it guides it into place.
Do not seperate the wear ring from the seal at any time.
Why do you not want to separate the seal and wear ring?
Yes, it has been rebuilt. I am asking questions, based upon putting the motor together 4 years ago. Does the seal itself get any kind of sealer or lube prior to installation?
hope this helps..be doing mine soon only on a stand..
Glad to help.
On the PDF, I see no where that loctite is mentioned, just RTV. Did I miss something? Can't wait to play with RTV, picking my skin off for weeks is fun.
