rear main seal advice...
Mad Max
in, out and all around the matrix you live in
So. I'm fixing to do a rear main seal on my 94.5 powerstroke, never have had to do one before on these trucks so is there anything I need to know about, I e torquing down bolt around the seal ect, or is it pretty straightforward? Thanks
roughstockcowboy
TEXAS
Its easy, if it has been replaced before it will have a journal repair sleeve on the crankshaft journal, the new one if it ie oem will have one.
Dieselboy.
Surrey B.C.
If its not leaking dont touch it lol.
If it has been done and has the sleeve on the crack you have to remove that as its part of the new seal.
I used the spacer and 3 bolts to run it on with, just have a friend man one ratchet an run them in together. Use nothing but the grey death rtv.
Bugman
Gypsum, Co
The big thing is that if you have a leak make sure of where it is leaking from before you replace the rear main. They don't go bad on these trucks very often.
85_305
Valley leaks are often confused as rear main seal leaks. They RARELY go on these trucks.
94TurboDiesel
Wisconsin
Make sure it isn't your oil pan gasket leaking first I just finish pulling the motor on mine to put in a new oil pan which I thought at first was the rear main but it ended up being the gasket under the rear main and the pan were cracked
