strokefreak
Going to be installing the traction bars this weekend i hope. But i have a couple questions as i have never installed these before. Keep in mind im in an rv park 8 hours from home, with basic tools you have in your truck.
1. How do i determime the best length to set the heim joint at? I assume the forward frame brackets must be on the flattest,straightest frame area i can get them.
2. The rear axle bracket is the type that the u bolts go through and it sits underneath the axle. Do i leave the trucks weight on the ground to change this out one side at a time?
Any advice is appreciated as ive never done this i stall before.
