Red Truck build...part 5
powerstrokedkid87
New Jersey
You're running 3.73s I assume. How did your old setup spool with those big 38s?
yea still running stock gears....truck ran really well with the 66/71....spooled around 2000k IIRC......was fine for daily driving....original plan was divided up pipes and a t4 rather than the t3..would have improved the drivablility even more...but i got bored with a single set up..and craig made this set up look so tempting, i had to do it.
jdc753
Norton, MA
well the first package finally came in, set of steeds, up pipes, and some turbo piping....the rest should be here today! gona be a busy week ahead of me
Sweet :redspotdance:
looking forward to some progress when you can get all the parts. Probably won't make it to any of those events except for nationals at Englishtown and the XDP day, but really looking forward to seeing the new changes and what numbers you can get out of it!
powerstrokedkid87
New Jersey
same here Josh.....look forward to catchign up with you guys again down at nationals for sure.....
I got two turbos yesterday, just waiting on one final "Big Package" from craig which should be the last pieces of piping, fittings, injectors, ect....hope to have these over the weekend.....
All i can say is its going to be a late week comming up for sure!
powerstrokedkid87
New Jersey
some progress this weekend.....got the steed manifolds on, MPD up pipes on, and started messing around with clocking the 66. Rest of the parts should be here wednesday. Planning to have this truck on the road this weekend! More pics and updats to come.
tonight il try and pull out the old down pipe....and finish mounting the turbo..
powerstrokedkid87
New Jersey
Got some more work done last night, injectors are in, started clocking and mounting turbos....starting to look like something
pass side injectors in, all buttoned back up
Driver side injectors in, and buttoned up
changing the exhaust housing on the 480
Quickly mounted the 480 in place.....long way to go, but progress!
jdc753
Norton, MA
well, the truck is running...but some definite issues to work out....only 10psi of boost at the moment......
That's the built in MPD speed limiter to avoid liability
Least it is up and running, some trouble shooting and hopefully you will be burning the tires off in no time.
Josh@DirtyDiesels
PA
It's ok mawkk even if you dyno'd it yesterday the numbers would have been off cause that dyno must be messed up LOL LOL
powerstrokedkid87
New Jersey
Looks like its going to be a Blow off Valve issue, gta get some customer trucks out of the way, and il get to it. Hopefully tonight if i have some time.
Josh i heard that, prob a good thing it wasnt up and running...might have really hurt some peoples feelings haha.
Hope to be cruising this week in the truck!
Josh@DirtyDiesels
PA
It's ok... when it is if you want maybe we can go up to dale's shop and dyno both the trucks. I wanna run mine on spray on that dyno to shut some people up lol
powerstrokedkid87
New Jersey
finally fot the blow off valve hooked back up, trucks build boost great now. Next is to load up the tunes, and spend some time under the hood cleaning everything up
powerstrokedkid87
New Jersey
Im working on it josh, emailed eric this week about it. That seems like the last thing on this truck is just getting the tunes figured out.
