For example, Swamps wants $255 for ABs and $257 for ADs, both new Alliants. Around $2050 per set. But you have NEW injectors.
For their stage II splitshot remans $1575 with 5yr/200k warranty, however no description of what size these stageIIs are. Have to call, I guess.
Swamps also has several flavors of remanufactured injectors with the same warranty at a range of prices.
If you really wanted to spend the bread then you can get modified injectors on new bodies.
https://swampsdiesel.com/shop/products/ford/1994-5-03-7-3l/injectors-1994-5-03-7-3l/1999-03/
Call the injector remanufacturers and see which ones leave you feeling warm and fuzzy.
Used to be the case that the injector manufacturer wanted the cores back to keep them out of the hands of the rebuilders...:flipa:
Ended up with new Alliants, glow plugs, valve cover gaskets and pig tails. Thanks for the help
I have never regretted going with new AC's. 100k miles never a hiccup. still idles smooth as glass. Next ones may be modded ones but will be built on new cores. I've followed this a long time and I think there are about 5 people in the world that truly understand how to make a PSD injector perform properly. I would trust several of them but was able to afford new so why not.
When I bought mine I was able to use my fleet contacts and get them at vendors cost. They had just removed the requirement that exact cores had to be received, now they just need to be the same series. And yes they are trying to keep cores out of the market.
What would be different in brand new/remans? Arent all the remans done with all new parts? What are they leaving that will wear out/break prematurely?
