Replacement of displacement
Powerstroke Man 6.4
Do you have boost or drive pressure leaks?
shouldn't 180's and 38R be around mid to high 4's?
I had 160/100's and 38R and that thing lite quicker than stock and had no smoke at all.
brackin2000pstroke
litchfield mn
I need to do a little checkin but I'm wondering if it's my cps.. Driving it lights quick after 10-15 pounds.. But has always been smokey...
Sent from my Z970 using Tapatalk
Well I guess i wouldnt call it a piece of ****. But alright
not being a dick bud and i know you can only push so much fuel through stock nozzles but at that power level(assuming the dyno was right) it should clean up way better then that. I'm simply saying you have issues somewhere!
not sure with the stock nozzles. my dually smokes less then that wot and the track puts it at over 450hp.
brackin2000pstroke
litchfield mn
Had my bosses 08 on there and he pushed 550/9something with. Setup calling for that power range..everyone seemed to be happy besides one cummins
brackin2000pstroke
litchfield mn
Powerstroke Man 6.4
Nothing popping up as odd on scanner but that don't mean a thing
As I stated before check for boost leaks etc if all the PIDS look alright on the scanner.
shoot 100% nozzles cleaned up to a slight haze to nothing on my old 7.3 and that was on my full fuel tune.
brackin2000pstroke
litchfield mn
I don't feel any leaks around turbo flange or up pipes.. I don't have a leak down tester either.. Hmmm
