Trav-O
I need to rig up a tow bar to pull a F450. Anyone made one (with pics)?
Sure any for F250 to F550 will work the same
your safety chains are invisible!
How did it pull? Anything you would do different if you had todo it again?
I looked at a 08 truck that was 1000 miles away and thought about towing it the same way. Ended up not buying it but still was wondering if it would have worked.
I see your help must be invisible too. The man had to get a job done. It worked and he did it himself. If more people were like this America would be a better place.
Other than no lights or chains, I have seen way worse..
Excellent thread. Thanks for sharing. Need to build a tow bar to pull a f350 drw. How did you hook up the tow bar to the excursion?
