Rigid light bar.
Snake
Flo Rida
So, back on track, are these lightbars something a guy can drive with on desolate roads? As in, nobody is around turn this on and its easier,safer to see? I could get into.this if so. I already gave wifey the heads up on buying one if it'll work.
I have mine tied into my high beams. Figured if they were on, its ok to add a little more light. And there's one less switch on the dash.
7.3psd97444
Indiana
Thats not a bad idea. I too dont like alot of random switches and **** everywhere. lol
Hell no, me either. I would probably wire into the headlight switch like the factory fogs so I could run them with high or low beams.
Snake
Flo Rida
Factory fogs turn off with the high beams, don't they? It's been so long since I've had mine I can't remember.
HOOV3R
Central PA
On the 05-07, you just have to ground a pin at the fuse panel and you can run fogs all the time. I can't remember the pin number though, but there's a write-up on one of the other forums.
Yea, or a britebox setup(high and low beams simultaneously) which allows the fog circuit to remain hot always. So long as the switch is pulled out.
one2nine
Altoona, Pa
That's what I'm running now. I wasn't trying to tap into the SJB on the 08 and ups. Looks like more work that what I want to deal with or the fact that I hate wiring.
