I just started running T-6. It has a much better idle when cold and zero noticeable difference when warm. My truck has always ran oil temps between about 25 and 210 with the 195* thermostat. Even prior to the T-6. It definitely isn't any louder when warm, in fact I would say it is quiter the warmer it gets. (Never been above normal operating temp though).
Over the years in my truck I have used Rotella T 15w50 conventional oil almost religiously with a 5k miles oil change interval. I did have one oil analysis at 7600 miles on the conventional Rotella and Blackstone recommended running the next oil to 8200 (iirc, either way at 7600 miles they recommended going a bit longer) as everything still looked good and check it then. I never went that long because I just wasn't comfortable running to it's limits and would rather change it with a little bit of life left. I have no oil analysis for the T-6 OR the Valvoline Premium Blue that I ran for two oil changes. The Valvoline ran like crap. It was loud and didn't run as smooth. MIGHT have been my imagination, but other friends with 7.3's that were familiar with my truck agreed.
Overall I am happy with the T-6. The reason I decided to give it a shot was a combination of postings on here and there was a report on Bobistheoilguy (I think that was where I saw it) that compared a whole bunch of different oils and since they reformulated the conventional Rotella T and it dropped down in quality for the older motors the T-6 was near the top of the list in additives, quality and performance in analysis. Personally.....It's probably all smoke and mirrors and just about any standard oil will do the trick if changed in a reasonable time frame regularly, but Rotella T and T-6 give me good piece of mind and do the trip. Your mileage may vary.
-Aaron
