Did you clean the mating surfaces of the rotor/ hub? Go back and check the torque on the lug nuts to make sure they are even. They can be turned as an assembly if needed.
Did the caliper push back hard?
Most common issue on older brake systems is dragging calipers after they are returned to a fully released position. All the junk in the brake system settles in the bores and sticks the piston when they are pushed back into it. Do your self a favor a replace both at the same time if you find this is your issue.
