Rudys IC cold pipe
blk350on20s
I have it. I dont see how itll go without grinding but maybe. I ground mine down. Mines actually for sale. Replaced with no limit
Cajunhunter67
Trout, La
Thanks fellas. I went and ordred it. Trucks in the body shop getting the front replaced. Good time to change it. Rudys will flow much better than stock. Looks like they hit it with a sledge.
one2nine
Altoona, Pa
Even if you do grind the support it's the casting lip on the back just to make clearance. Unless the pipe is pre-dented pretty much all of the IC pipes require grinding.
