S366 VS Full Force BASB Bell 300 series Turbo
Gainesville Ga.
You planning on a 6.7?
Was... but bought the 06 in my tapatalk signature, I need to update my actual Sig too
06-6.0l, studded, reworked heads, egr ******, blue spring mod, 6.4 banjos, dummy plugs, stand pipe, upgraded stc fitting, New oil cooler, New ipr, New icp, atlas 40 FICM, stage 1 powermax, and Looney wild, 325/65R18
ChattyCathy
Oh I missed that...sounds like a clean well setup truck.
PSD POWER007
Columbus, GA
Jody runs a HFSB and 180/80's on his excursion and it produces nearly identical to my BASB and 180/80's. So I have no clue what happened in Curt's case but glad he's happy now.
m j
BC Canada Eh!
Love my BASB with 175/80s.
The BW S400 series turbos have clearance issues in the OBS trucks. You have massage the firewall for clearance.
Stick with a T4 series turbo, there are much more turbo choices available.
Billy T.
[email protected]
the firewall for the DP was a pretty big mod but the one spot the turbo might touch was very minor, I gave is a smack just because but I am not sure it needed it. I will try and find the pic of the sharpie mark I made on the cowl area that I thought was suspect.
the downpipe required a fair amount of work, I am glad I had a portapower for the t4 install (had to loosen the body bolts and push a bit to get ds uppipe to go in as well)
blaze42069
BC Canada
Wow that big turbo and only the 2 " manifolds? You know they make bigger ones hey.
