Swaan
- Joined
- Mar 19, 2012
- Messages
- 734
- Reaction score
- 0
Also, it makes sense that Pigs would come up with a compressor wheel that flows more air than a 366 but spool faster down low. Otherwise, you could just go to a smaller 300 series turbo that has the faster spool up without the higher cfm flow and spend less money. Can't wait to get mine
Everyone always thinks it's the compressor wheel size that dictates how fast a turbo will spool. Although this is true to a certain extent, the biggest effect on spool comes from the turbine side. As in the size of the turbine wheel and the A/r of the ex housing. The basb uses a 68 mm tw. The 366 uses a 74 mm tw. Big diffrence.
