7.3obs
- Joined
- Nov 18, 2014
- Messages
- 205
- Reaction score
- 0
Sorry I haven't been on much guys, I plan to get some sort of reader, I am using an iPhone. I do plan to get. Tablet or some sort of andrioid device because I have heard a lot about the torque app throughout the years. I plan to tune my truck myself, cut down on this fuel and get some of the shift points a little smoother.
I took a 3 hour drive for work today, seems when you're under the turbo for awhile it throws that check engine code, peg the throttle and there's nothing there, throw it in N turn key back then fire it back up and it's fine. Did it maybe 4 times today. Either a bad sensor or I have a faulty uvch because if I'm in tune 01 and just BARELY on the throttle, 15-20 mph truck skips too. This winter I plan to rewire and get the soldering iron out and get the dual iprs 100% wired clean and also replace all the uvch connectors!
As I said, winter is coming and I plan to park the truck soon, I blew the transmission in my work truck so I plan to get that replaced soon and daily that again. Once snow flys the truck will be parked and I will start buying other stuff, traction bars, two new tires for the rear, and for sure everything to tune it myself.
All in time!! Truck does run decent for now though I will say. It is a lot of fun!
