shopping list????????
luv2brode
fixing to order parts for my early 04 f250 heres whats on the list so far:
bpd oil cooler
egr delete
exhaust-turbo back
blue spring kit
banjo bolts????
what else do I need to get since im there
thanks
TheReelMuhcoy
New Jersey
That depends on your goal with the truck. What is its final purpose and use? ie. reliable work horse, street fun, street/track, track only? HP goals?
Also how good are you with doing your own installations? U can save a TON of money by doing thE MPD oil cooler/filter relocation system.
luv2brode
good Question the purpose of vehicle will be reliability limited towing 5th wheel.
used to be an auto tech for 13 years
I looked at the mpd but when I spoke with them they advised they did not make a kit and to put one together it was 1300+
TheReelMuhcoy
New Jersey
I built mine for under $1000, and in either case that is significantly cheaper than the BPD system, and works just as we'll.
You are on the right track for a simple reliable weekender-tow truck. I and many others will recommend also doing studs for peace of mind when towing a 5th wheel. I would say get an Edge Insite so that you can monitor ALL of your temps etc. in one place.
