Youve adequately checked pressure and the system does not hold pressure when pump is off. My pump runs at KOEO, but will shut off if you do not start the engine within about 30-40 secs. At that moment, pressure drops to zero-- but, if I was to just start the motor at that moment (without rekeying the pump), it will light no problem.
42psi at idle is not causing haze-- there is plenty of pressure for the demand. 5 might but 42 wont. 42 is even ok to cruise on but not for max effort-- you should have 60-65
My concern is why you show 3ms of PW at moments of when your ICP is at idle pressure. It should drop to idle PW (less than 1ms). If that is really what is happening (vs having a datalogger glitch), that might cause haze and overfueling.
