yzmatt
Silverpsd 06 where is wellsville ks.? I'm row up south of Ottawa.
On the straightedge thing. I do have one on each bank, the same too second one back that are ever so slightly higher. Like a 1/16" maybe. But wouldn't it show something before today? Just figured it was a fluke
I don't have near the experience necessary to answer that but I can tell you that if you dont get an injector fully seated in the cup that the copper crush washer will allow combustion gasses/heat to pass up to the lower oring that seals the fuel off. When that oring melts it will allow fuel to piss out into the cylinder, which in turn causes the smoke and raw fuel smell out of the exhaust.
With a Big As Hammer. NO not really. My hand until the last steel ring and d then a rubber mallet finishing with using the hold down bolt to finish it.
What is the correct way to seat the injectors?
Hated hitting the top of the injector on the solenoid.
Towards the end I was hitting the bolts on the edge of the solenoid. Figured that may be better. The bolt probably did the last 1/8' inch. After I torqued them down I hit the tops one last time with the mallet for good measure and then checked the torque and they were all still good.
Ok I'm pulling them off tomorrow and redoing them all. You have given me hope. I was ready to light a match to it, except diesel won't burn like gas will. HAhaha
