so, ficm started crapping out on me yesterday.
sleeps
Virginia Beach, Virginia
luckily i have a week before i need to drive down to florida. unexpected expense, but at least i was prepared. i had a feeling it was going to be soon just not right now. glad it didnt happen a few hundred miles from home though and really toast...real bad, rough startups, 5 mpg drop and no giddyup and go anymore. just dont want to ruin injectors or get stranded.
so, which one should i buy?
swamps?
bpd?
vivians?
ficm repair?
someone else?
48v or 58v?
need to buy today or tomorrow so i can get it here before i leave.
Zmann
the BPD 6 phase is the only real "upgraded unit" IMHO
second I would go with the 4 phase
the rest u are waiting your yours to be resoldered maybe have the voltage tweaked maybe programmed with a tune and returned
s0 in a nutshell if time is your enemy go with the BPD new units unless you live close to one of the FICM repair places
Zmann
Or looking at your sig fix yours yourself?
and get the BPD when funds arrive if $ is an issue
can I ask if you verified voltage wise that it is a FICM issue ?
sleeps
even with an electronics backround there is always the chance of making a mistake and damaging it further, especially while in hurry. thats why i wanted to buy one then ill take a look at my old one, fix it, and keep it as a backup for me and my dad (his is stock, bound to happen eventually). if i had no time constraint i wouldnt hesitate to just take it to my shop and go at it. i just dont want to have to reschedule my leave.
weazel
Elkview WV
I went with ficmrepair.com awesome customer service, and I am really pleased with the job he did
Sent from in a ditch up side down and on fire with the wheels still spinning
Extended Power
And with the BPD unit, you can select 48,53, or 58 volt output on the same unit, correct? (phase 6 unit)
Snake
Flo Rida
Correct. It comes as a 48v FICM, and there are two wires you have the option of cutting. Cutting one of the wires makes it a 53v FICM, and cutting the other wire (not in addition to the first, instead of) makes it a 58v FICM. If you cut both wires, you have a 48v FICM but lose the redundant circuits.
bboteler
Virginia
i have a 58v flashed with the atlas 40...been on the truck for two years and works great, came from Swamps originally.
Dave
The BPD 4ph and 6ph units are the only truly upgraded units.
Nothing on the power supply is stock its completely reengineered.
After that I would go with FICMrepair.com
Its a stock unit with upgraded components
Zmann
I didn't hear that u lost the redundancy u don't when u cut 1 of the two when u choose the upgraded voltage from what I was told when I was there
but a replacement set of jumpers would be simple
or fixing the cut in the existing jumper
ps The 4 has has no redundancy if anyone was curious but it is all new upgraded components
Zmann
u have the better 4 pin now
u can't swap between the 4and 7 without doing the whole unit vs the half shell
Zmann
IDK when they changed but the early ones were 7 pin
takes a minute to pull the cover and check but I think the 7 pin was 03 maybe early 04 only
