SPE CCV kit
bpan
I don't know how this is but the fumes were pretty bad on my No Limit kit on my 2011. Always got the comment "your trucks on fire" lol
alewis
Probably because those new cabs seal up better
Also, after 300 miles the inside of the hose is still as tacky as when I installed it... zero sign of oil coming out of the hose
Powerstroked6.7
Washinton
If this dosnt have a baffle like the mpd kit you will get alot of oil drips in your driveway, ,I had a straight thru kit before, that's why I upgraded to the mpd with the baffle
Powerstroked6.7
Washinton
When you get closer to your oil change you will see, and it gets worse over time as the oil builds up in the hose, when I had a straight thru kit without a baffle I made a catch can with vent holes but it got messy so I bought the mpd kit
alewis
We shall see
Will update in a few months I guess
alewis
Now it’s leaking
seems like it can’t handle excessive pressure/ rpms
Black AOD
Ohio
No Limit CCV kit into a No Limit Catch Can, venturi into the exhaust for vacuum. Zero issues, 20k miles on this setup.
Drain the catch can every 5-8k or so.
SDER1
VA
Had this on the list to do... and eyeing the SPE kit...did a diy run on my 6.0 for 7+ years and only dripped minimally once when Hotshot Eliminator was used vice 9100...
