Squeak when shutting down engine?
Ctsvnino
North jersey
It started happening after I did the ******. By looking at it its spinning quickly as you turn the key it stops fast with a squeaky sound and shake. I don't know if you can hear it. Wonder if it's under warranty or it might be a simple fix. Any body have this problem or suggest anything
https://vimeo.com/141596759
BOHICA256
Midland, Texas
I can't watch the video, but my truck did it too. Then it just stopped. And it'll do it every once in a while but I could never figure out what it was.
Ctsvnino
North jersey
ccmac
Texas Panhandle
Also if your pickup is warm enough that the fan is kicked in it could be from the weight of the fan screeching to a stop against the belt.
strokinpower
Greensboro, NC
Thats the cummins squeak lol. It's because when you turn it off the compression will spin the crank backwards a bit when it shuts down is what I've read about it.
