Stack?
SoCalPSD
Riverside Ca
How i got it
Almost done
Done
And yah i know my welding sucks
SoCalPsd-Corey
Big Bore
9000ft in the CO Rockies
And before the fail comments start comin about it being taller than the cab. im not done, couldn't get ahold of a chop saw big enough to make a mitre cut so i cut the turn out off and left some room. A Flat cut was the best i could do with a 4 1/2 angle grinder
SoCalPsd-Corey
You know what, not a fan of stacks in general, but I definitely like that square cut stack. It's unpretentious. I'd leave it.
thunderin jimmy
Mesa, AZ
i didnt want to cut the support under the bed so i just moved the stack behind it. sits about 4in from the bed rail.
also, i used a flex pipe 90* because i was afraid of engine torque putting stress on it if it was mounted solid to the bed.
