I remember I got the same talk from Joe way back in the day. Well about learning the motor before I talk about it anyway. I even text in full sentences.
***er...
just telling you guys what happened to me. I assumed it kept dumping more icp to keep the truck running. I literally had barely enough fuel pressure to keep the truck going down the road.
yep most likely ur draining ur fuelbowl or its getting to hot i ran stage 3s witha stock turbo and this happened
Just realized why I had that code. And fuel pressure was part of the problem. the other part was I had the skinny pedal mashed for 3-4 miles till there was a safe spot to pull over.
Again, The PCM has NO way of knowing if you have 5000000000 psi of fuel pressure or 0... You can start the motor on starter fluid and keep it running, the ICP will just keep driving the injectors without a care in the world...
i had it cleared and it wouldnt come back on(SES) UNTIL ON THE WAY HOME
