Timmy
Within the last 3 months I have replaced both batteries, starter and both battery cables bought from ford. No matter if the engine is hot or cold, when I turn the key to the start position the starter will click like it's bad but if I continue to hold the key in the start position, after 3-5 seconds the engine will crank and fire immediately. It's like the starter isn't getting a good enough connection to turn the engine over, it was doing the same thing with my old starter, which is why I replaced it. Any ideas on what it could be? I've got a battery drain somewhere as my vacuum pump and blower and radio will run with the truck off and key out of the ignition. Tired of throwing parts at it and it not fixing the problem. Thanks for the help
