sleeps
according to insight and dummy gauge on dash.
i had a problem a while ago not being able to make over 28psi, i had a bad exhaust leak, then found a whole in the hot side cac and the factory plastic cold side was cracked up. i figured that MUST be whats causing the low boost. well i fixed the exhaust leak and welded up the hole in hot side and bought a new metal cold side cac pipe.
still cannot make over 28psi. truck spools a little slow but it feels like it gets up and moves pretty quick once it spools and shoots straight to 28 and stops. any ideas? things to check?
