Stock 6.7 with wide stance
ChattyCathy
[/URL][/IMG]
[/URL][/IMG]
bigrpowr
<How I Fly
Administrator
here's my 08' with 22x10.5
and my 2013 with 22x12 ( bag of diks edition ) which i ***king love...
MiXiN mike
Thanks for the pics guys. I am looking at 20x10, nothing much wider with probally a -24 offset. If done right I think it looks pretty badass. Not going for the low rider look, just want a more aggressive stance. I am not planning on a lift as I stated before due to the fact I Use my truck for pulling our 5th wheel camper. I am also not a fan of lifted trucks sitting on rubber bands. I am old school, back when tires actually looked like tires, not thin slices of rubber, way before the big wheel look, which I really don't care for. Really enjoying the new truck.
Nj67
South NJ
Older pic of 20x10s and 35s. 3.5 lift though...33s would probably fit just fine
Squat and Poot
Houston, TX
exact combo I am getting(wheel and tire size) any trimming involved? I don't want to hack up a new truck. In order for the truck to sit level is a 4" block needed in the ear and the 2.5" kit up front with a 1/2" spacer on top of that?
trimmed front bumper bracket and a little liner previously for 35s but these fit with more room
2.5" front needs a 4" block, add a 1/2" spacer in front and you'll need 4.5" out back
my front is about 1" and a hair higher than the rear when it doesnt have 400 lbs of in the bed
UNBROKEN
Remember they're not all the same. Mine with 2.5" front springs and 4" block needed another 1/2" up front to sit level.
2.5" front and 4" rear block is a pretty solid combo though for a mild lift.
BK39
Texas
22x10s with 325 50s on the Platty. Stock 4wd.
20 x 9s with 305 55s on the work horse. Stock 2wd.
Had to pull the fender liner back a hair on the work truck. Minor trimming involved on the Platinum and fender liners pulled back. I too wanted a wider stance, but didn't want to lift it.
bigsmokey531
NY
here's my old 11 with a 2.5" level and 22x14 with spacers.
My how things have changed..i have 12 wides on my old truck and they baaaaaarely stick out. A 14 would look like the 10.5s do on mikes green truck.
04cr450
harford county, maryland
Thanks for the info. I'll get a couple 1\2" spacers from pmf trevor- there only $15 a piece so can't hurt to have on hand in case the the truck sits rear high
