Stock wheels and bigger tires
PSD-BLACK-CLOUD
TX
How wide of a tire can I put on stock wheels till I can get aftermarket wheels? Will a 13.50 work?
MINK
London,OH
13.50 will work but you will want to play with the psi so they dont wear to awful.
036.0l
I have a set of 37/13.5/16s on my stock dually rims right now. No unusual wear so for. Have about 1500 mi on them.
Sent from somewhere, somehow.
Manytoys
Fort Saskatchwean, AB
How wide of a spacer are you using and how much gap between the tires? I'm looking at getting some 35/12.5/17's toyo MT's soon but am concerned with the width on my 12 F450 6.75" rims.
PSD-BLACK-CLOUD
TX
Sweet I was woried about them being to wide to sit on the rim. I wonder If I am going to need to run a spacer to push them out from the frame........
HOOV3R
Central PA
13.5 in what size 35, 37? On what size wheel 20? You'll be able to get away with it better on a smaller wheel, or with a larger tire. It all depends on what your going to run.
TexasA&M
Ft. Worth, Texas
What is the best way to figure out the optimal PSI? I'm getting ready to put 325/60 tires on my stock 20" rims. This babies are expensive, so I want to make sure that they wear evenly!!
PSD-BLACK-CLOUD
TX
I ran that set up no problem on my old truck. No wear issues at all.
6.4psd916
Roseville , CA
I ran 33x13.5 on factory 05 18's, no issues. Use chalk to get the psi right. Mark the tire and drive straight a few tire turns, let pressure out till it wears straight across the pattern.
