studs egr wheel time!
Worstenemy453
Fredericksburg, Va
PMed.
The Black Onyx gaskets are too thin, even before being compressed which is why they fail. The only gaskets worth using are OEM and then secondary would be Hypermax.
PTSUPERD
I have a new set of OEM fomoco gaskets on the shelf in the garage right next to my un opened box of ARPs for when the time comes.
Buddy@MPD
Glen Burnie, MD
The batmowheel is a good idea. I just put one in not to long ago and it lowered my egt's and picked up a little bit of hp and torque on a stock charger.
bismic
OEM gaskets use five metal layers, while the BO gaskets use only four, while the OEM ones also have more pronounced firing ring sealing surfaces.
stonepusher
San Antonio
When decking the heads, DO NOT mill to Ford specs......make sure the machine shop decks them completly flat. Get them magnifluxed as well. Might also wanna look into a regulated return fuel system while you have the cab off.
