Stumped need help!!!!
Tncoalroller88
Piney Flats, Tennessee
ok so i took it for a test drive and its definetly reading boost at the map. If get on it hard in 5th gear doing 45mph it will fog like craxy in the all out setting just no go:shrug:
02BigD
Coastal NC
What's boost doing?
Since all the posts yesterday, have you swapped chips and test driven it?
Gearhead
does 5lbs of boost on the boost gauge show 5lbs on the OBDII port? this would be a map of approx 19.5 psi.
2000wa250
What altitude are you at?
14.0 at idle seems a bit off honestly. Should be 14.7 I believe. Not a huge issue but could point to a sensor that gets further off the higher the boost pressure is.
Who's injectors? How does it sound?
What's your icp at throttle when its hazing?
Btw I wouldn't criticize dave. The guy understands more about these engines and tuning than the majority of people that aren't doing this as a job.
Sent from my DROID BIONIC using Tapatalk 2
Tncoalroller88
The boost gauge reading 5 psi came to like 19.0 or 18.??. These are casserly injectors and I'm not sure exactly on the altitude I'm in the east ten mountains tho.
And as for Dave I wasn't trying to seem like a dick but there was no use in saying really and sayin how he did. I just bumped the thread to get people to read it for help
Tncoalroller88
I will check those boost numbers again in a few to make sure tho cause it was dark last night and a brightcomputer in your eyes ddriving is a pita to read n drive in the dark
Gearhead
And on the stealth mode tune..... chances are I just need to up the timing a bit for that truck.
Tncoalroller88
Alright man that's cool just what ever u gotta do to make it not smoke like that. I hate havin problems with this truck it drives me insane. My only deal is this is the only transportation I have and if the chip is sent back it will be down id what to do .
Gearhead
we offer a trade in program where you pay a deposit on another chip then we refund you when we get yours back.
