kyle43335
- Joined
- May 18, 2011
- Messages
- 2,364
- Reaction score
- 0
You maybe going in alittle bit over your head with just going into those injectors with 350 small block logic.
This is absoloutely hilarious to me, Its like he isnt even reading what you guys say, everyone says hibrids, he says " what about BXXXXX "
Dude are you really just phuckin stupid? ? Like previously stated, you have some of the smartest 7.3 people around telling you hibrids..
I think I have it figured out though.. youre the kinda guy that wants to do stuff just to say you did it. Even tho its EXPENSIVE as SH!T to do it your way, for little or no gain, just so you can tell your buddies at the bar that you mcguvered the balls off your truck and it STILL runs.
Do these guys a favor and just stop posting. You wont listen to anything they suggest, just start a build thread and in the first post say you dont want anyones opinions because youre gonna do it how you want.
Yes a hybrid can easily make 500 but so can a BD code with nozzles as plenty 10 years back seemed to be making 500.
The blower is not a restriction. Once the turbos suction overcomedoes push of the blower the turbo sucks the unrestricted owould open and pulls air from atmosphere thru a second filter. Once this happens there is lites no load on the blower. Eatctually has tested the TVS to state that it uses about 1/2 hp in a bypassed state. The blower itself is only helping part throttle low load situations. Once go to a larger turbo (planning on a 4xx frame turbo) then it may at that point be benificial to increase blower speed to fill the gap and help a single laggy turbo spool up faster. Several of these positive displacement blowers have been fed in the same way into compounds.
I am also planning to remotely place the turbo on the passenger side of the engine for ease of cold side plumbing. Right now it goes blower/intercooler/turbo. After the larger turbo it will be blower /turbo/ intercooler. It will also clean up the valley.
Yes a hybrid can easily make 500 but so can a BD code with nozzles as plenty 10 years back seemed to be making 500. Hopefully by late summer I should have most of the work done and can put it on the dyno at DDPs annual dump event.
Other than that does anyone know if the BI codes are still a oil thirsty injector once modded to single shot. I know the BD codes have the larger intensifier which would cause an issue as far as volume but the B code split shots have the smaller intensifier?
Yeah I'm not stranger to warping stuff. At least I will have 12 to mess with. I may buy a TIG I no longer work at a company that has a TIG at my disposal. I miss having a TIG welder building stuff just isn't the same anymore lol.
I've been repairing CNC presision cutting machines for 9 years now. I am no newborn to pulling stuff apart with small parts and puttings them back together. Besides if you don't try to learn with your own hands you never will. After looking at the exploded views of the internals they don't look that bad. Just need a nice clean area to work on them like rebuilding a cutting spindle.
Probably not. I already talked to a few shops that can flow the heui injectors. They all want to disassemble the injectors to inspect for contamination before they put them on their machine and that puts quite the cost up there. I do plan to take my time and replace all the o rings and inspect for damage and worn out parts. I am in no hurry.
Wait... What if this is the most epic TROLL thread in PSA history...
there is NO WAY he can be cereal
Seeing the other blower over turbo builds a couple years ago, I was going to be quiet and wait for the results ...but.. The OP just said that 8 random old injectors would be randomly DIY hand worked by a newb and NOT run across a flow bench? Are you getting ANY assistance from an injector shop? What are you using to torque the halves back together?
If we were in a post apocalyptic wasteland, hoarding fuel, and speaking Australian, Id get it.
Speaking of grenades, its the only game where 'being close enough' is ok. Injector building is not.
Regardless, have fun and carry on...opcorn:
I just see a complete lack of understanding by the op. Not of his ability or career. I just think he doesnt understand how and why to do things a certain way with a 7.3. As I said, he is in a safe zone now where there isnt enough fuel to cause anything tuning related. With tiny injectors there is no point, with larger ones there will be no benefits.
This is an awful lot of work for a guy who is happy with 300 out of a 7.3, I just don't see the point. There's not even a cool factor of saying I did it differently at that point.Majority of my driving daily is flat ground to work and around town and I rarely rev the 7.3 over 2-2200 ish which will likely be a happy plane for a roots blower hence why I am going with one. The other reason is to greatly minimize smoke. I don't need 500hp I am happy with 300. Not a race truck i want drivability.
Now he doesn't think he'll surpass 600, no chit sherlock you already said you're happy with 300.I don't need 1200 ft lbs I am running the ZF5. With all the Talk about BD codes being worthless yet a few have put some big power down with BD codes? I don't pull or race so maybe the ZF5 will hold together considering I don't really tow and haul much and don't launch it. Torque kills but shock loading seems to tear stuff up quicker. I don't need a hypermax block lol. I doubt I will ever surpass 600 if that. ZF5 would not even hold the torque at that point.
Wait, I hope the "play" plans don't include sled pulling or drag racing on occasion.Daily driven street truck. Gets me to work and doubles as the hunting rig/play truck. Many have ran the stock BDs and BIs as is without any major downside. In fact it was JDUB that stated he rather have a stock BD for a street truck over a hybrid. That may be how the truck was tuned I am not sure. I'm willing to give it a shot. I can also spin the blower faster latter to cure any smoke issues. It's currently only spinning 11,000 ish rpm with a red line of 19,000
