madman1234509
Ok so as many of you know Ive had some issues with my truck since getting it back from having a bunch of things done to it over the last few weeks, I wanted to start this thread to get out of the thread about my hg job. So here is the story
My truck went in for a head gasket job, heads were cracked, have brand new heads, new ford gaskets, arp studs. Made a custom downpipe, custom egr delete with a 50mm jgs waste gate and a regulator. Custom CAC pipe and intake elbow. RCD cam, valve springs and ported rails. And a crank case vent mod
Problem. The main problem im having is when the torque converter is locked, on every tune, I mainly just run the 310. Roll into the throttle, the truck does this surging, you can hear it in the exhaust note, and sitting in the truck. It doesnt loose a ton of power or anything but its very noticeable. It ONLY does this with the torque converter locked, when I get on it without it locked it runs awesome. The two main things Ive notive is exhaust back pressure spikes all over the place when this happens, but it relatively low. And VGT duty cycle is all over the place during this. The truck also shudders a tad bit only around 55mph barely on the gas just cruising but thats not my main concern right now.
I have take the waste gate off since then, pressure tested all ports, does leak, pressure tested the regulator, doesnt leak... pressure tested the entire intake system on the truck with no leaks. The waste gate is currently closed completely with the regulator until this problem is resolved. I unhooked the VGT and drove it, didnt surge anymore, but obviously you cant just drive around with the vgt unhooked all the time. The highest boost I can see with the tq converter locked is like 38 pounds. No codes read with the DD. Otherwise the truck runs awesome. I drove it over 700 miles this weeeknd with no issues. Here are some vids, and a graph pic. I can get pictures or info of whatever you need. EP reads 14.1 with key on. Boost gauge doesnt read negative or any crazy numbers. Throttle position sensor doesnt fluctuate or do anything crazy.
All videos are 1/2-3/4 throttle with the torque converter locked
Here you can kind of hear the surging
http://youtu.be/LJ9fANpBZPU
Gauges on DD
http://youtu.be/MUlXOZcQ__Q
VGT duty cycle all over the place
http://youtu.be/14otGAZEHvs
Gauges on DD
