Smokin 6.0
I'm building my own T4 mount and need help figuring out where oil feed and oil drain go and how to hook them up. Anyone who has done this in the last pictures would help tremendously.. Thanks
I think I am going to at least buy the T4 mount and up-pipe setup. Then go with a Holset Turbo. And make my own turbo drain. If I use the mechanical fuel pump port in the block. Does anyone know what size the tube has to be ?
I think you may need to do a bit more research before tackling this.
If you havnt checked out Irates site, you should look at the complete cost of a full kit along with the turbo options. Study the pictures until you know what you are looking at.
http://www.iratediesel.com/store/buy-online/
People typically buy the full kit ^^, some have made their own.
http://www.ford-trucks.com/forums/1270170-big-reds-build-thread.html
http://powerstrokearmy.com/forums/showthread.php?t=60949
Oil drain needs to be much larger than supply, supply is 4an. Again, you wont have to worry if you buy the complete kit. If you intend to construct your own, I would plan on it taking a while unless you have a extra motor to mock up on, along with a lot of ground work.
HX50 is a T4i. At least mine is.No Holset Turbo as in a HX50. I will be running 250/200's
