Tim @ P.I.S.
A quick glance over it was at 3.9..it's real hard to watch all 3 at the same time.
Another longer run I saw 4.2 and the pump was still at 3000psi @ 48% dc
Thanks Jason. Have a pm headed your way.
BTW...Your rig is a f'ing animal!!!!!!!
Quickest OBS I've been in. Not just fast but quick!!!.
Just so snappy and responsive.
I'll let Billy Give the details, he just did a bunch of stuff.
I found another data log I did on an Excursion with stock injectors switching from a stock under 100k pump to a T500. I do not remember any of the details on this one though.
Interesting how the pulse width is lower when the pump is able to meet the demand. I have observed that before.
I don't want to sound like a dumby but what is the highest ICP you should see on a stock pump in a hot tune? (with stock injectors) I have NLTD tunes, if Jason would be willing to share what the tuning should be calling for in the hot tune. Im reading the icp through the OBDII port and in the hot tune at WOT I've seen a steady 3600 psi...is the OBDII port not accurate or is my pump a freak?
The lower PW with the pump keeping up is due to the demand of fuel being called for as a "volume fuel desired". If the pressure goes up the pulsewidth goes down under most circumstances if the volume of fuel being asked for hasn't changed.
Oh wow! Stocker holding 3600psi is really good. But I would think thats plenty for the injectors.. so its holding steady at 3600psi or is it spiking to 3600 and settling down to a lower pressure all the way through the rpm band?
alright, I looked at the log file and Lincolnlocker nailed it, I saw pressure spike up to 3400 psi on this WOT run and then she bounced between 3000-3100 psi. I think before what i saw displayed was the max value the app recorded. this makes more since, cause the tune is asking for around 3200 psi. seems like I found my answer lol
sorry for the double post but I have another question for Jason, when i got my tunes last year i told Jonathon that i had plans for either a billet turbo wheel or 38r in the future could he have upped the icp demand based on that? just a thought.
