Ok, Ive made comments a few months ago about a random converter lock unlock/lock in top gear. Over the past couple weeks, its become much more frequent and has now thrown a p0741. I know that's a general TCC code and could mean many things. The driving observations;
-trans shifts fine at all fluid temps
-converter locks on time in 3rd like it always had (at 35mph).
-converter locks firmly as normal (no strange behavior)
-converter function at slow speeds seems very normal
-trans shifts to 4th as normal/on time (50mph, with light throttle) with TC locked, but if you hold throttle position and continue accelerating, it will begin to unlock/lock (I have a light wired showing TC lock and it will blink off at same time it unlocks)
-lighten throttle position and it will stay locked, but as you tip in, it will unlock then lock
-Have TC lock override switch. It will lock it if unlocked at slow speeds and it will stay locked at any speed when engaged.
-When the switch is on, you can see the converter lock light blink every time it tries to unlock it
-trans temps have gotten slightly higher during last few weeks, but not out of control. Still no more than 100-105F over ambient. Ive discovered if I leave the lock switch on, it controls temp much better. The lock/unlock definitely heats the fluid up.
This issue 'seems' to have gotten worse since the 20s were installed. (Have not reset speedo.) Im viewing it as it takes more throttle input/load with the taller/heavier tires.
In reading on the web, some have said it could be VSS related but no VSS codes. It seems that my choices are to check the wiring, replace the solenoid, check line pressure. What input drives the solenoid to lock/unlock? Im developing an opinion but want some other thoughts.
Its due for a filter anyway, so perhaps I'll take a look around.
What else can I check?
