Tensioners and Belts
BigNiner19
South FL
Looks like the main tensioner is seperating in the middle. Everything seems to be running normal, but I can see some seperation. 149K miles
I also see some wear on the accessery belt for the AC
I think I just want to replace both tensioners and both belts.
Do most of you replace with the green back belt from gates?
Also - Is it necessary to remove the fan shroud?
Zmann
I order all my stuff from sunrise ford a sponsor on here
guaranteed fit with your vin / free ship and way cheaper than any dealer near me
f350guy
Texas
OE tensioners/idlers. Gates green belts here, I would have considered OE belts again too.
Remove at least upper part of shroud, if you have air tools... Lisle Tools make a set of wrenches that fit an air chisel and will pop the fan clutch right off. WELL worth the investment.
