The Little Truck That Could - [Build]
Crack85
Midland, Tx
I've been on here a while, I guess this build started about 4 yrs ago when I just wanted tow powers and a stg 2 trans....and then I met Shane...let's just say things snowballed from there....This is actually my 3rd 6.4, I wanted to make sure I had a nice one before I put a new engine and trans in it. I knew this build would take sometime, so I bought a long block and transmission (from derek@visiondiesel) and started from there. The build has changed directions more times than I care to count, but got a little more in-depth with each iteration.
Before even starting the build list - I'd like to thank whitemonster@pointzerofab, webb_06, Nathanial, JD, Jared,Tadd@elite, gman1, Mike@nolimit,Derek@visiondiesel, layson and that CAT35niner guy. Without any of these guys the build would have probably never made it this far.
The Truck - 2010 F250 Harley Edition (45,000 miles on Chassis and Engine)
The Engine -
Everything internally has been cryo'd and coated.
Block machined, oringed, bored .030"
Mahle Pistons - coated, fly cut, delipped
Crank Polished, Rotating assembly balanced
RnR Billet Rods
Elite - LPFS and Dual Fuelers
Ported Heads - coated
RCD pushrods
Steed Speed manifolds v3 - (I've actually owned all 3 versions)
Custom XHD uppipes
Colt Cam
No limit Cold Side kit
No limit Coolant Tank
RCD Oil Pan
Pointzero custom coolant lines and driver side
Elite flexplate
Elite Stage 4 Transmission
13 " DPC converter
Bulletproof Diesel waterpump
Precision Intercooler
A1 - Custom Aged 625 Studs
Elite Stg 2 valve springs
Elite HD Lifters with extra oil bearing
RCD 60% Injectors - flowed and balanced.
New Rockers and oil cooler OEM (Empire let me down, thought they would have released their **** by now).
Elite CCV
Alradco Radiator
ATI Damper
ARP - rods bolts, crank bolts, damper bolts, flexplate bolts, exhaust manifolds.
GoGo ported intake manifold.
Elite billet oil pump
I think that's it, or at least all I can remember.
Turbos -
Elite High Powers, Gen 2
This is something that changed so many times i have lost count. Initially I wanted to shoot for 4 digit numbers. Then I eventually came to the realization that now that I'm married, breaking this thing repeatedly wasn't really an option. So high powers will have to suffice.
Suspension -
OUO.
Wheels -
Welds - got more than one set to choose from so I don't know yet.
I'm still missing little odds and ends. But I hope it makes 800hp and I finish by the end of the yr. Pics of progress to come.
Thanks,
Austin.
Black AOD
Ohio
Thanks man, I hope so!
Sent from my Nexus 6P using Tapatalk
Dude!
Why have you and I not talked? We literally have clone motor/trans/fuel/turbo setups. Except your motor has rods and ported heads.
Thanks Matt (Cat35Niner), for not telling me about this guy's awesome build!
Crack85
Midland, Tx
Dude!
LMAO!!!! Yes sir. That Matt guy is a tricky one. Gotta watch him, lol!!!
CAT35niner
NJ
Dude!
Umm I think I did but I am very sneaky.
