The next level
06f250powerstroke
ontario, canada
Hey guys I want to step it up a bit, i've got a new daily driver and now i want to take my 6.0 and make it a puller and racer. but i'd still like to drive it on the street sometimes. need some ideas on what to do? turbo? injectors?
is there any point in a 225 hybrid?
SleeperDuty
There was someone doing a build with 300/150 Hybrids? and a custom built s400 based turbo from puis a while back.
Pizza pig
MD
the turbo is forcig the air through them, any 6.0 or 6.4 will benefit greatly from ported heads, which I also would look into. Im not sure if you have a ported intake, but thats another great idea in conjunction with the headwork.
Pizza pig
MD
that 66 will be replaced ;)
either way you can still make huge power with the stock heads.
strokin6L
Springville NY
Man Iam looking at Procharging My truck with a Billet wheel hybrid from MTW, Tell me more about your setup!! I was thinking 285/150's or somthing.. F1 R maybe? What is your headunit an D1SC??
You don't want to use a VGT with a procharger or in a twin setup. If you use a procharger setup...use the F1 not the D1SC. The F1 is larger and is the one you'd want.
Pizza pig
MD
danny ran a procharger feeding a stock turbo with 225s a while back, the vgt is just fine.
strokin6L
Springville NY
yeah and it will have HIGH back pressure as well....that's what the vgt is known for. Same aspect as using a vgt in a twin setup. Sure it'll work....depends on how much bp you want and how long you want to keep your head gaskets. Why do you think Danny ditched the vgt.
