ThreeFitty
Last week My truck started dropping out of drive when I was sitting at a stop light,but only when the trans was over 170/180. Give it a little of the skinny pedal and it will go back in gear and off you are. It shifts perfectly otherwise, except for some rare times when it misses the 1/2 shift and I have to back off and get back into it, and that's usually only when I'm turning off a side road and trying to get up to speed on a main road with the trailer behind me. I dropped the pan and found a lot of metal. Mostly small shavings but more than a dozen large chunks and shards. I'm thinking the pump is eating itself and its not building enough pressure at idle once the fluid gets hot enough. At this point the truck has 190k on it and has only had a solenoid replaced in the trans. I think it's time is coming.
That said I am thinking of buying an upgraded trans just to be done with it. This truck is only ever going to have tunes on it. It's a 100% work truck and I want to take care of this before I'm stranded with the trailer on or a load of topsoil in the bed. I am looking at the twisted stage 1 and am going to call them today. Just not sure where else to look. My local place wants $3800 to put a stocker back in, but I have access to a lift and a willing friend to help out so I think I can manage this job. Any feed back is appreciated. Thanks
