Tire guidance
RyanD
Hey guys, I'm getting ready to pull the trigger on tires and would like some advice.
Going 35s (maybe 37), and reading up on specs, I've got a couple of questions. For starters, I'm sticking with stock 20s. I know a lot of you run 35x12.50 on 8" wheels, but based on the load rating and width I'm a little hesitant. I've also seen 295/65/20 that are higher load rating, but are more expensive.
So, really, how safe is it to run 35x12.50 on an 8" wheel? I daily drive mine and rarely go above 75mph. Maybe I'm over thinking this, but I'd like to get some opinions before I pull the trigger.
dsberman94
Pennsylvania
No matter what size your tires are, you should be going with an E weight rating. And a metric size tire should cost less than a standard or inch size. In the same weight rating.
RyanD
Thanks!! Everything I've considered has been an E rating, so it looks like 35x12.50 is back on the table. I've seen a few local guys running them on factory wheels here too.
Strokersace
Towanda, KS
Where are the facts behind your comment so I can research this theory?
dsberman94
Pennsylvania
Which part exactly? You would comfortable tow a heavy trailer or haul a heavy load on a D rated tire? Or that typically a metric size is cheaper than an inch size, because at least in my experience they have been.
Strokersace
Towanda, KS
The metric size vs inch size comment...
Jomax
Arizona
I tow comfortably with a D rated tire. It's still a 10ply and has more weight carrying capacity than a stock tire. I don't see where all the negativity is for this. Maybe some D rated, but not all.
RyanD
Thanks guys. Going with the Mastercraft mxt then in 35x12.50. I don't tow or really load it down. Just don't want a bead breaking at 75mph.
Strokersace
Towanda, KS
Still waiting...
And yes, I've towed a lot with D rated tires. Heavy loads and highway speeds. Thru mountains and on the flat. I prefer an E rated tire, but am no way scared of a D rated one. I 2nd what Jomax stated.
So I've answered your question, answer mine.
cbf9703
Still waiting...
Agreed on both. I've towed with D rated tires, but prefer an E. I was also wondering about Berman's comment about metric versus inch comment.
Although, it is Berman, I take his advice with the grain of salt it was intended.
patricku47
Santa Fe, TX
I have a buddy of mine that has been running these tires for a while now. He tows heavy with them pretty regularly, and exceeds 75 more than he should and loves them.
dsberman94
Pennsylvania
Still waiting...
I looked it up online and yea some are a bit cheaper in metric. Congrats, you proved me wrong. Being I was going off what a tire shop told me not my actual research, I probably shouldn't have opened my mouth till I looked it up. Not looking for a pissing match so congrats again.
Strokersace
Towanda, KS
So, tell me, what is the difference between a nitto mud grappler 315/75R16 and a nitto mud grappler 35x12.50R16?
Please tell me, I really want to know.
cbf9703
Dude, you were doing good. No need to act douchey about it all, but this is part of how you've earned your reputation...
Str8Ugly
Odessa Tx
i have a 315/60r20(same as a 35x12.50r20) on my truck when i had them on my stock rims it almost felt like i had a lot more sway. once i put them on 20x10 wheels that went away. once my new 37's come in i will be putting these 35's on my stock 20's
