Tire wear?
montana6.4
Montana/north dakota
So on my passenger side front tire its wearing every other knob outside edge. Has leveling kit, adjustable track bar and has been aligned couple times. Will castor affect tire wear? Ball joints seem to be fine.
Sent from my XT1080 using Tapatalk
Csilva187
Most likely Montana is your problem. Honestly it's rare to see a set of tires wear nicely in my parts. Now I'm kinda/kinda not joking mind you. They should have check castor etc while aligning? I hate fighting tire wear with our roads lol.
Big Stroker 6.4
Caster is a stability angle. Camber and toe are tire wearing angles. Did you get a print out of your alignment specs?
ToMang07
Mainah!
I imagine the roads there are heavily crowned as they are here.
How often do you rotate?
montana6.4
Every 5 to 7k miles think that may have been some of my problem. Their getting down in tread and I may have let them go a bit long.
