Torque Converter slippage
Jeff@Spartan
Georgia
I would assume that looking through your PID list, you should be able to find whether or not the Livewire has that PID.
powerstrokin15
Charleston, WV
i do have one. so does it or no?
just browse through your PID listing on your livewire.. easy enough..
but here is a PID list i found by googling it....
Coolant temp
Desired exhaust backpressure
Desired fuel mass
Engine oil temp
Exhaust backpressure
Injection timing
Injector pulsewidth
Inlet air temp 2 (degree C)
Intake air temp (degree F)
Manifold absolute pressure (Mpa) - not gauge pressure, real pressure
RPM
Vehicle speed
Boost pressure gauge (PSI) - This is what the gauge reads from
Dpf pressure (Kpa)
Dpf regen status - This is a counter so you know how long for regen
Egt 1 offset (degree C) - factory sensor
Egt 2 offset (degree C) - factory sensor
Egt 3 offset (degree C) - factory sensor
Frp desired (Mpa)
Frp (Mpa)
Pedal position
Torque into torque converter
so i guess it can
Jeff@Spartan
Georgia
Depends on the value used. The DashDAQ monitors it using RPM. I think it is understood that anything between 0-10 is error. Beyond 10 is actual slip. My truck was still perfectly drivable with 100+ RPM of slip when I punched it with the converter locked up. However, the converter was obviously slipping so it wasn't putting all of the power I had on tap to the wheels. I have never seen anything close to 100 with my SunCoast and the converter locked up.
cory151
Damn I didnt see this as one of the gauge options i the Mini Maxx, wonder if they are calling it something else. Oh well, guess Ill just do like I did on my 7.3, if it still pulls its ok.
Cajunhunter67
Trout, La
I dont believe the SCT livewire has Converter slip indication. It has torque input indication which has been as high as 900ft lbs, also It has torque converter speed. It usually stays at 1.64 on mine, but have no idea what its really measuring.
