Bignbadbelair
- Joined
- Oct 22, 2013
- Messages
- 83
- Reaction score
- 0
Yes def was. My question tho is how soon so I need to change the other solenoids since they are .1-.2 off spec?
could be TC solenoid also.
Changed the torque converter solenoid today and on the way home the converter hasn't locked up whenever it's not supposed to. We used a ohm tester and checked the old solenoid we took out and it was reading 5.1 instead of 4.1-4.7. Also I started checking the rest of the solenoids while we had the pan off the others all read 4.8-4.9 besides the line pressure solenoid it was within spec. 5.4. So since the rest of the solenoids are .1-.2 higher then what they should be do you guys recomend changing them?
I was thinking about buying them as soon as I can but how soon do you guys recomend I change them?
