Ouch
Dont think it would handle a real snowfall good, but I guess with our tax dollars at work it doesn't matter since across the country they feel its necessary to plow 1/2" of snow off the roads...
I've never used either (then again, my idea of plowing snow requires a farm tractor and grader blade), but I suspect this tow plow would allow the driver to see the end of the blade a little better than a wing.
Are there generally speed limits to using a wing? I've only ever seen them used to push a snow bank back into the ditch or just further back, and that is pretty slow going. It looks like the tow plow would be able to run what ever speed a std blade could run.
For the first storm event, Viking-Cives provided a driver trainer to ride with the Department’s operator
and train him on the proper use of the unit. After some initial trepidation, the driver quickly became
comfortable with operating the Tow Plow.
... equipped with a six ton capacity hopper and material spreader positioned underneath the trailer directly in front of the hopper. This configuration allows the operator to not only plow a second lane but treat the second lane with salt as well.
... one Ashtabula County Transportation Manager commented, by means of the TowPLow and one additional plow truck, this was the first time he had seen Interstate 90 cleared in one pass from grass to grass in 32 years of service.
... With a single plow truck, the section of US Highway 20 where the TowPLow was utilized, normally takes three hours to plow and treat one pass on all four lanes. With the TowPLow, this same section of highway took 45 minutes to complete one pass on all four lanes.
A typical heavy-duty plow clears three-quarters of a lane, or 9 feet. Mounted with a side wing-plow, it can clear 11⁄2 lanes. But with a tow plow, it can clear 21⁄2 lanes, or 25 feet.
the TowPlow is more forgiving to a hit than a traditional wing and consequently the truck stays more in control. Also, because we are able to plow the snow back further, you can gain up to 14 feet more (depending on your wing set up) than a traditional plow and wing.”
– Randy Reznicek
St Cloud District Winter Maintenance Superintendent
Minnesota Department of Transportation
