hold up... I have never seen that fitting for the oil filter housing to allow 2 hoses for connecting to a external air/oil cooler. I have seen the BPD external but it removes the whole oil cooler. Where can I find some info on this? is it new? thanks.
Read the whole thread.....but here are some answers.
I designed and built it, it is the only one like it out there, and I’ve been running it for almost a year.
It is set up, and designed to piggyback onto the factory cooler and work as an auxiliary, and is not intended to bandaid a factory setup that has high deltas when running empty.
As an auxiliary it uses a 215* thermostat, and was designed to add heat shedding capability for towing heavy.
I’m sure it could be run as a stand alone if I eliminated the factory cooler and put a 185* thermostat on it, but I haven’t done that yet.
It keeps all the factory filters, and could be run on an engine that has the egr still on it.
Some of the parts are available off the shelf, quite a number are not.
