Towing with sct canned tunes?
PSTROKED_SSG
Taking a 1800 mile trip next week from missouri to Alabama and then to Tennessee and back to missouri. I will be pulling my 25ft enclosed with atvs and camping gear inside(apprx 6000lb). I have an innovative tow tune but currently run sct canned performance as a DD. can I run the canned or should I just reflash to the tow tune? Sorry for the long post thanks in advance. Chris
WoodBoy
Alabama
Im not sure how the canned tune tows, but I've towed around 5,000lbs heavier than that with my gearhead hot street, and IDP extreme street and extreme x
BFT
southern cali
I've towed 12k+ with the "TOW" tune and I wasn't a big fan. I changed it over to innovatives xstreet tune and it towed great.
Corb@CorbinShipping
Autryville, NC
i tow 20 K in the STREET tune... The TOW tune pissed me off... Kept kicking down, never had enough boost to build speed on uphills... STREET worked great. less weight than that, I would say X STREET woul;d be fine. But Mine is a bit touchy, so I cant use it... Unless I am playing...
forcefed6.4ford
Medicine Hat... Again
I never tow with anything smaller then a 210-215hp tune. Truck handles heavy loads with ease. Corb and I gross about the same and I have never had any issues. Completely stock save for the deletes.
tbsimmons
Bakersfield, CA
I tow on the Tow Tune most of the time. This weekend I am going to switch to the Street because of the new intercooler from No Limit. Corb and I have the same trailer. The reason was the tow tune I didnt have to watch gauges. I have a lot of steep hills to climb around me.
I have towed 7000# on a tag with the X-Street. It was fine, just a touchy throttle. I would not even think twice about that weight on the Street Tune.
PSTROKED_SSG
So I just reflashed to inovatives tow tune and now it won't boost past the 30 psi mark on the dash. I've had this happen before and I just returned it to stock and loaded it again but it's a bit annoying! Anyone else ever in counter this?
tbsimmons
Bakersfield, CA
Something is up then. Loaded on the tow tune I could hit 40-41.
The street tune this weekend will hit 48 though, scared me a little. But she just grunted over the hills not even a down shift.
Corb@CorbinShipping
Autryville, NC
See.... STREET is SWEET! LOL So long as you are happy with the temps and EBP, should be just fine. I was in Spartan 275 EL, with 17 K behind me last week... 49 lbs boost, 54 EBP, 1200 EGTs.... 15% on ramp to I-10... 70 MPH in less than 1/2 mile, uphill from 10 MPH...
tbsimmons
Bakersfield, CA
This weekend when I had the Livewire hooked up, usually use an Edge Insight for Gauges, I saw in the in the 470-500 KPA which is in the 68-72 PSI range.
Take off the 14 from idle and I am in the 54-58 range not to shabby.
forcefed6.4ford
Then your trans said "*** THIS SH!T! I'm outta here!" LOL
