Towing with tunes
tbsimmons
Bakersfield, CA
Depends on the total combined weight and how connected your right foot is to your brain in your top head.
If its only the truck and a jet ski anything.
If its 20,000# behind the truck and you have to climb 7+% grades I would only use a tow tune.
When I had my 04, when I towed over 10,000 I used the tow tune, anything udner I towed on a street tune. Just watch the temps.
06-sixoh
Bakersfield
I'm reviving this, because my searches are NOT producing anything I want.
I'm going to need to haul my friend's crew cab 1500, 2WD sierra about 2 hrs North of me in the next two weeks. My '16 is warhammer tuned, and want to know if the fueling is too aggressive to tow with. I'm guessing I'm only going to be at around 7k, maybe. Mostly flat land, 65 MPH all the way up.
Thanks.
Jomax
Arizona
Thanks.
I tow 10k plus in my race tune. With 7k pounds, I wouldn't even worry. That's me though.
06-sixoh
Bakersfield
7-8k isn't hardly any weight at all, but I haven't towed since tune. Thanks. I'll leave warhammer loaded and just drop it down a notch. Maybe.
tbsimmons
Bakersfield, CA
My 16 is not tuned so can't comment on them other than I would watch the temps with the truck in high gear and also slip on the TC. Lot of torque to grunt over stuff.
06-sixoh
Bakersfield
TB.. Maybe I should just talk you into swapping trucks for a day. Think that foe-fiddy will pull a half ton to Fresno? LOL
tbsimmons
Bakersfield, CA
I need to change my picture. I sold the 450. But yes it would it is a beast of a truck. The 6.7 stock is amazing to me though. The 350 I have now is an animal. I can't imagine tuned.
Thanks.
let her rip tater chip!!
workingdan
Thanks.
I tow my 18k toy hauler with mm canned street tune with no problems. Temps get a little warm on steeper grades.
06-sixoh
Bakersfield
I was thinking your new super duty was '450 too. Right when you said that, it clicked.
I really liked the way the stock truck drove. I hated the regens and constant supply of DEF.
