Track bar for 02
ToMang07
Mainah!
Another thing was my shocks. As you can see their all pretty much rusted and some leak. But with a spring pack like I have, is there even a reason for shocks? I mean this thing rides rediculousy harsh. I doubt shocks are even doing their job
Get some good shocks, sized/valved for your truck. Springs support the weight, shocks control the bounce.
DEEZUZ
NO PUKESTERS
NWI
When I say there is no bounce, there literally is next to no bounce. I'll toss some On later, I really want to get this front end knocked out.
K_Hood
Gainesville, FL
I feel like I could use a little R&R on my front end...so I will be following this thread! :thumbup:
On a side note, I absolutely love the grille you have on your truck. It's a nice blend between the painted sport and a billet. :drool:
DEEZUZ
NO PUKESTERS
NWI
Thanks man. I'll be ordering the bar and stabilizers tomorrow.
DEEZUZ
NO PUKESTERS
NWI
Last thing. I noticed my front driveshaft is too long. The blue spline insert contacts the u joint on hard hits. Do I have to get the shaft cut and if so, how much?
DEEZUZ
NO PUKESTERS
NWI
I'll see if I can get a good angle tomorrow.
But I noticed contact marks on the rear side of the old u joint. I put in a new one and it has the same. Marks along with the grease I put in the boot of the spline when I had it apart. I can only. Assume when I hit hard the shaft contracts and contact is made
jngreen
IN
That could be why your truck ride is so harsh.
DEEZUZ
NO PUKESTERS
NWI
Is it common to cut a shaft after a lift? Or could it not even be the right shaft?
dsberman94
Pennsylvania
Sounds like your driveshaft is too long if I'm thinking about what your describing correctly. Like someone replaced it with a longer one.
Btw disregard my last post in the beginning.
artieb
Hey ToMang, how tight are the bushings? Are they poly or rubber and has the bar been holding up? I appreciate your input, thanks Artie
ToMang07
Mainah!
In post #5 you can see it, it's the same as the OEM bar, steel bushing in rubber. And as I said in post #2, I beat the piss out of it, off roading, plowing, towing, and REALLY bad roads, lol, no issues yet.
artieb
thanks, I seen your picture is better than the sellers picture. I appreciate it! if the bar can survive this winter and snow plowing is doing pretty good
huck2080
fyi looks like a fabtech lift / new better shock will make a world of differnce on the harsh ride
