Traction bar time
Coop980
oregon
Got board today so started on a set of traction bars. There 1.75" .120 hrew with poly bushings for dodge front link arms.
Sent from my DROID RAZR using Tapatalk
Coop980
oregon
That is pretty small pipe. Are you going to add any metal between them? Plate or some more tubes?
Garrett
probably getting paid at work to post this from my POS phone
Why do you say this is small pipe? Most rock buggys are built from 1.5" or 1.75" tubing same with most internal and exo cages.
SSpeeDEMONSS
6mi from the beach, SoCal
1.75" .120 wall is small. Most rock buggies don't weigh 6500+ and if they do I hope they aren't using 1.75" .120 wall unless it is chromoly. Couple the weight of our trucks with the amount of torque they make and .120 wall quickly becomes inadequate. If it works for you more power to you.
Garrett
Coop980
oregon
Well since a lot of guys online I see are building there traction bars out of sch40 pipe I'm fairly confident I won't have any problems. Maybe you know something I don't but lot of koh buggies I have seen use 1.75" .120 wall and driving a powerstroke I'm not worried much about torque.
Coop980
oregon
With lift springs it doesn't move much, its also the style bushing 90% of companies traction bars use unless you do a double axle mount with a shackle mount to your frame.
Coop980
oregon
Who makes traction bars for OBS trucks?
On past obs trucks I have had them from rancho,tuff country and pro comp, since most traction bars bolt to your axle and frame they can be fairly universal to most trucks
neverkickn
AR
I see you mentioned you have a lift but when you get them installed you might want to compress the springs the full amount you would expect to ever see to make sure they won't hit. That h style bar makes for a very tall profile.
Looks good though!
Coop980
oregon
Looks good though!
With both tanks full and my 110gal bulk tank full my 3" tuff country springs move about 4", no where near the travel the 4 link on my crawler has but doesn't really need it.
f-150_xl
Oakland, Md
I have L&L on my obs. They aren't bad. Not the best looking but they do the job well.
Sent from an Iphone and most likely misspelled, mis-categorized, and misunderstood...
