Ok I'm having issues with my transmission. It's the 5R110. First I was told that cut fan clutch wire was causing my issues. At the time prior to repairing wiring the truck would go into limp mode and clunk into fourth gear and stay there until you turned truck off several codes at that time a few fan related. Now it seems worse after fixing the fan. I've got two codes p0715 and p0791. Now when you take off after about a hundred yards the truck comes to an abrupt stop and will go nowhere kind of feels like someone's holding down the brakes if that makes any sense. It does this whether your in drive or manually put it in first or second or third it still does it. Any thoughts? Solenoid? Sensor? Filter? PCM? Tcm? I'm lost thanks a lot!!!!!
