WichitaF250
05 with auto tranny. Delayed shift from R and also D, once in reverse works great. Drive with engage after a short time 2-3 seconds, but bangs in to gear. Once going it’s fine until you slow down then kicks out of gear. Then it seems like it takes off in a different gear then shifts down and goes. Tow haul will flash in stop and go traffic.
Dropped pan only small amounts of dark materials around magnet. Put new filter on and put new fluid in the ford stuff. Same problem. Next step replace direct clutch solenoid?
