Is there a reason NOT to go with a comp unit? I am at 200k miles and got a fairly finicky trans so replacement is coming soon. I don't ever plan on being at rod bending power but would like to get to the point I have my 63mm non vgt maxed on fuel so not sure I need a comp but if shifting is not different then why not?
Yes there are a few guys that are running a 369 and dual fuelers......then there are guys like this one. I pulled these out and it was a damn mess....
It just isn't worth the risk.
I wasn't talking about suncoasts transmission
I was talking about the torque converter itself
Them having the quad lock with multiple stall options is a little more versatile
Now, my 15 has roughly 800 at the tires, through an HD Converter
BUT, I am putting a Suncoast converter in my Comp trans to roll out and be sure
+1 for Midwest. Just shy of 700hp and only issue has been a solenoid. Which was cheap and easy to replace. Other than that no issues. And I tow 15K on a regular bases.
Gotcha. I was referring to Midwest's 2 versions of transmission. My experience with TH350/TH400/AOD/etc...has been that when you really beef up internals and mess with valve bodies that shifting becomes somewhat unpleasant for daily driving. If all things being equal between a street and comp Midwest trans other than strength would it be worth the extra $ to get the comp if I'm only ever going to be putting sub 700 hp?
Honestly in now way is daily driving unpleasant for me and i have the comp unit. They say on there site anything over 650 they suggest the comp unit. Im still not sure what my exact plans are for mine but i went with the comp anyways just so i have the extra space. Like i said im in love with my trans. I promise you you cant go wrong with one of these
Cool! Thanks for the post! Almost makes me want to get one before mine grenades.
let me know when you're ready i'll hook you up !
